Sold/Expired ATTENTION TOYOTA TRUCK and BUGGIE OWNERS
XRR
Member
We have an abundance of Trail-Gear parts in inventory. Below is a list of items that are ready in stock and ready to ship. Please PM or [email protected] us for more details
Thank you for your time and consideration.
XRR
P/N Description
100001-1-KIT Trail-Creeper Case 21 Spline Dual Case Adapter
100063-1-KIT Speedometer Extension Cable
110008-1-KIT Shackle Kit 5.5", Front Offset
110026-1-KIT Frame Tubes, Kit
110042-1-KIT U-Bolt, Flip Kit, Front 79-83/Rear 80-95
110043-1-KIT U-Bolt, Flip Kit, Front 84-85
110046-1-KIT Shock Mount Kit, Pair
111308-1-KIT Bolt, Greasable M 18x150mm
111314-1-KIT Bushing Rear Leaf Spring
120089-KIT Gusset, 3-Holes
120234-1-KIT Small Diff Armor
130002-1-KIT Steering Arm Set, 4 Stud
130020-1-KIT Pitman Arm, Flat
130586-1-KIT Rod End FJ-80 Right Greasable
130587-1-KIT Rod end FJ-80 Left Greasable
130599-1-KIT Pitman Arm, Drop
140006-1-KIT Knuckle Rebuild Kit w/o Bearings
140011-1-KIT Brake Line Kit (2 Front 1 Rear) 26" Long, DOT Approved
140031-1 Differential Set Up Kit 4 Cyl.
140033-1-KIT Magnetic Drain Plug w/Aluminum Washer
140035-1 Inner Axle Seal
140059-1-KIT Solid Pinion Spacer Kit: 4 Cyl
140060-1-KIT Solid Pinion Spacer Kit: V6
140135-1 R&P, 5.29 4cyl Trail-Creeper
140157-1-KIT 54mm Axle Socket
140160-1 R&P, 4.88 4cyl Trail-Creeper
140171-1-KIT Knuckle, Stud, Hex, ARP
140181-1-KIT Wheel Bearing Seals
140325-1-KIT Trail Safe Inner Axle Seals (Pair)
170004-KIT Knuckle Pull Scale
180156-1-KIT Taco SAS 3.4 Oil Pan Conversion Kit
180190-KIT Weld On Flat Tab 9/16" Hole
180517-KIT LED Light - Clear
301076-KIT PS Pump Bracket Kit, 2.7L Tacoma
301688-1-KIT Longfield™ 30-Spline 4340 Chromoly Super Set
301699-1-KIT Longfield™ 27-Spline 4340 Chromoly Super Set
Bought a set of 4.7 TC gears through XRR a short time ago. Price was better than most and fast shipping. Being a small business owner myself I know well nothing goes perfectly all the time and we had a hick-up along the way. To Benjamen's credit he resolved the issue quickly and without hesitation. Would definitely deal with him again. thumb.gif
