Barnes 4wd
- Joined
- Aug 29, 2013
- Messages
- 399
- Reaction score
- 0
Barnes 4WD 4 Link DIY Kit 7/8" Heims
All Kits ship with brackets pre-drilled to the correct bolt hole size and no extra cost!
http://www.barnes4wd.com/4-Link-DIY-Kit-78-Heims_p_211.html
This is the kit that has all the parts that we are always using in the shop for customers single triangulated four links suspensions. This has all the parts that are made to stand up to the abuse that rock crawlers and trail rigs see and then some. This is great for the do it yourself fabricators looking do their own 4 link system. If for any reason you need to exchange any of the items in the kit just let us know and we will make a kit to fit your project! The kit includes:
1x Axle Truss
1 x Axle Link Mount Pair 0 Deg
1 x Truss Link Mount Brackets
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount Pair 20 Deg
4 x Chromoly 7/8"-14 x 3/4" Heim RH
4 x Chromoly 7/8"-14 x 3/4" Heim LH
8 x High Misalignment Spacer - 3/4" to 5/8" (pair)
4 x 7/8" - 14 Jam Nut RH
4 x 7/8" - 14 Jam Nut LH
4 x Tube Insert (7/8-14) 1 1/2" ID Tube RH
4 x Tube Insert (7/8-14) 1 1/2" ID Tube LH
Now only $433.03!
