Barnes 4wd
- Joined
- Aug 29, 2013
- Messages
- 399
- Reaction score
- 0
Dual Pull Winch Plate!
The Barnes 4WD Dual Pull Winch Plate was an idea born out of necessity. More and more rigs are tackling harder obstacles than ever. And with today's supper flexible suspension systems it is often helpful to "suck down" the front of your rig so that the suspension will not unload on a steep incline. This is where the Dual Pull Winch plate shines. Our winch plate has two opening one on the front for vehicle extraction and one on the bottom to so you can run your winch rope straight down to your axle. Your rope will need to just have a thimble end on it like the Master Pull rope in the picture so that you can easily thread the rope through either Fairlead. The Fairlead mount are the common 10" bolt pattern and the winch bolt mounting pattern is a 10" x 4.5" to accommodate a variety of winches. The winch pate is 26" or 33" wide and can be easily adapted to your rig.
