Sold/Expired Barnes 4wd TJ Rocker Guards
Barnes 4wd
Barnes 4wd TJ Rocker Guards​
Barnes 4WD TJ Rocker Guards give you the ultimate protection for your jeep venerable tub. Rocker guards should be first on the list for jeep body protection. Without rocker guards it is VERY easy to damage the rocker panel and prevent the door from working properly. Our rocker guards are made to go from wheel opening to wheel opening and slide in between the tub and the body mount. These rocker guards also maximize coverage under the tub as well. Barnes 4wd rocker guards are laser cut from 3/16” steel and come with counter sunk mounting holes and stainless steel counter sunk hardware for a smooth outer surface.
These are made in the USA from USA steel and cost $180.
TJ Rocker Guards
