Sold/Expired "BEATDOWN" jimmy smith buggy
NTIDWELL
This buggy was built in November of 2011 and redone by E.O.R. In 2014.
Motor. All aluminum ls2 403ci
Callie's crank
Compstar rods
Compstar pistons 12:1 compression
Ls7 lifters
Port and polished 243 heads
Cam motion .638. 246.6/252.1 110.1 lobe separation
Sfi balancer
Slp Dual Timing chain
Slp high flow oil pump
Drive by wire
Arp bolts and studs in everything
Transmission. TH400
Built with red clutches
Aftermarket hardened output shaft
P.T.C. 10" 3500 torque converter
Fwd manual valve body
Transfer case hero 2 speed
1.98:1
Tires and wheels
43sx stickies
Raceline rockers single beadlock forged wheels
Front and rear driveshafts are 1410 middle is 1350
Axles 2.5ton rockwells both steering
Both have RCV 2" 47 spline 300m shafts
Both have ouverson 300m spindles
Both have wilwood pinion brakes
All links are 2" 7075 aluminum
1"X1" heims
Steering dual Tc P.S.C pumps
2.5"x10" P.S.C ram front
3.0"x9" P.S.C ram rear
P.S.C orbital
Stazworks complete setup with self centering rear steer
Shocks blistein 2.0 fronts fox 2.5 w/D.C.S rear
Dual pass radiator w/4500cf fans all braided lines with AN fittings
Aeromotive a1000 pump and regulator and fuel rails
Fast 57lb injectors
All fuel lines are Russell brand hose with AN fittings
Seats are Corabeu ultra ss with prp 2.0 harnesses
125" wheel base
Sure there is a lot I'm missing Located in friedheim mo. (573)275-8213 call or text PRICE $60,000OBO. Only Trades I would be interested in is a RZR 1000 plus cash. Check out videos under Nathan Tidwell or Katie Tidwell Or for you book of faces users nathan&katie tidwell Beatdown buggy
Pic
nice buggy at a good price. the girl that drives it is pretty hot too.
Glad to hear you two are not getting out. I will let you drive Ol Heartattack anytime you want, but NOT THAT CRAZY WOMAN OF YOURS, she's a nut!!! molaugh
Haha thanks Stover!! And Gregg, I am easy on parts compared to 'ol Hotpants..he rough on sheet! :****:
Sure Katie, you maybe small in stature, BUT A SIZE 13 IN RIGHT FOOT. ie, Cable Hill Beatdown............... Great buggy no matter who drives it... :dblthumb:
Also jimmy Penner did all the wiring when he re-done buggy it's all clean and sealed also fuel pump has been rebuilt since AOP 25k bounty no more issues there. And motor dyno at 580hp. And thanks for all the bumps
Thanks. Austin. And a few might know this camera man don't mind the homo in the passenger seat
the homo in the passenger seat is his bff don't let him fool ya :drinkers:
