Sold/Expired BIG BLOCK CHEVY PARTS
I have 2 complete still assembled 454's and one 454 that was rebuilt but then had low oil pressure and was disassembled. Heads were redone when the motor was rebuilt. Disassembled motor will need the crank cleaned up due to surface rust.
You can call or text. I am located in the FL panhandle.
Justin
850-210-5397
Not to be a smartass, but what are you looking for? I have lots of BBC parts.
Really anything.. I am wanting to build a motor for my boat right now it is a bone stock 454 mag. I have intake and carb for it thought about going bigger stroker 540 exc.. I also have a 496 8.1 motor I could put in it, but am on the fence between old school and newer style.
What kind of boat? What HP level are you looking to acheive? Pump gas engine I assume?
24' Baja Islander I am not looking to do crazy 475-500hp, but It is hard for me to leave anything alone. I pulled the motor just to repaint the engine compartment a few days ago and replace some hoses.
Check out the 468 I have in the for sale section.
I have some rect. port 990 GM heads that would make 650-700HP for sale. Other than that most all I have a stock parts like oval port heads and such, which would work fine for you.
