Throwing this out there to see if there is any interest.
Here is the build thread on this rig.
http://www.pirate4x4.com/forum/showthread.php?t=803893&highlight=mjp
Buggy is Very Comfortable and should fit most anybody. I'm 6ft / 250lbs and have plenty of room.
DOM 1 3/4" Chassis 127" wheel base
Small Block Chevy mounted with solid motor mounts and solid Mid Mount
Propane Clear Tanks
140 Amp Power Master Alternator
Yellow Top Optima
PSC Steering Pump and Reservoir
Th350 Manual valve body with engine braking
Art Carr Rock Crawler Shifter
Hughes Stall Converter
ATLAS 4 speed 10:1 with cable shifters
Crawl Ratios
14.77 High Range
40.31 Reduction Range (2.7)
56.12 Low Range (3.8)
153.19 Reduction/Low Range (2.7+3.8)
Chevy 60 front .188 wall DOM truss
Custom built rear steer 60 .188 wall DOM truss
RCV Performance CV rear shafts
Locker in both ends with 5:86 Gears
1410 Joints through the whole buggy
Aluminum Links
Custom tabs 3/8in frame/axles
14in Fox Coilovers with Triple rate Spring Kit
Air Bumps on the rear
PSC double ended rams front and rear
Corbeau Ultra SS Wide Version seats
44in TSL's 90% or better
Beadlock
Disc Brakes on all 4 corners
Dual Wilwood Master Cylinders one for the front and one for the rear
Stainless Steel Braided Brake Lines
Custom Double Pass Rear mounted Radiator
$26,000
Chassis is unfinished (not painted) ready for your personal touches and choice of color.
Thanks
Mike
May take a Toyota Based buggy as part trade.
Pirate 4x4 build Thread
Propane Clear Tanks
Yellow Top Optima
Crawl Ratios
14.77 High Range
Aluminum Links
Beadlock
$26,000
Thanks
Mike
