Sold/Expired Buggy parts for sale
cdavidson
Member
Buggy part list for sale
- Front Dodge Dana 60, new brake calipers, new rotors and new brake lines, Solid diff cover 3/8’’ thick, new seals, currently 5.13 gears installed. I have a welded 4.56 ring and pinion to go with it. (1) high steer arm
- 14 bolt rear end, shaved for clearance, diff cover 3/8’’ thick, pinion guard, new brake calipers, new rotors, and new brake lines. Welded 4.56 gears
$1,500.00 for both
- 7/8’’ heims (8) 1 ½ .250 wall & (8) 1 ¾ .250 wall
$400.00
- (4) 2.0 16’’ Fox coilovers emulsion. Never used, brand new
$1,100.00
- (4) 17” KMC aluminum beadlocks 32 bolt. Never used, brand new, zero offset
- (4) 39.5 TSL’s (15/39.5/17) Never used, brand new
$2,500.00 for both wheels and tires
- 22re turbo, tubular top mount manifold, t3 turbo, external wastegate, 8LB spring, aftermarket cam, Eagle rods, LCE pistons, MLS head gasket, ARP head bolts. This motor is built and always screamed, ran beautifully! I can pull the oil pan if you want
$1,000.00
- Lots of other miscellaneous parts, multiple ECU’s from different years. Automatic 22re bellhousing and oil pan. I have this so you can bolt it directly up to an AW4 trany and have a bad ass automatic set up for your trail rig.
Call or text is the best way to get ahold of me (859) 307-9042. Everything is OBO but nothing crazy or lowballing. I’m located in Walton Kentucky (Northern Kentucky about 20min south of Cincinnati) My email is [email protected]
more pics
wheel width? willing to separate wheels and tires? price on wheels? thanks
17x9 wheels, I'm going to try and sell the wheels and tires together. If there is no interest here shortly I will separate.
Heims are QA1 and chromoly. They are the same ones from Ruff Stuff, I just got them directly from the dealer. They take a 5/8 bolt and the heim including both misalignment spacers measure out to be 1 7/8''
I'll put more pics up today,
Thanks everybody
more pics
more pics
motor pics
