Rock Crawling Forums
Building My Own Driveline - Opinions
Reply to thread
Message
<blockquote data-quote="84Toyota4x4" data-source="post: 1093857" data-attributes="member: 16626"><p>Well, just as an update and a conclusion to this thread, I went ahead and did it myself. I cut the end off my old shaft in a vice using a sawzall following the weld edge and it came right out with some big channel locks. Did the same for the CV end, but it fought a little more, haha.</p><p></p><p>Got them all out, made sure the cut end was square, then persuaded the CV into the tube with a 5 LB sledge. Once it was in, I made sure I had it in far enough but not too far, and made sure it was square to the tube. All looked good so I welded it up and shot it with some new paint.</p><p></p><p>Got it installed (after swapping t-case flanges because there wasnt enough room to drill the new pattern), greased the joints and took it for a test drive. Went well up to 35 MPH with no vibes so far. No exhaust on it so I was trying not to piss off the neighbors too much. I still need to cut and rotate the rear axle as well, but it seems to work great so far. I ended up with 1.25" of spline compression travel, the rest is all extension.</p><p></p><p>Of course some pictures as well...</p><p></p><p><img src="http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01113.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p><img src="http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01112.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p><img src="http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01114.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p><img src="http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01115.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p><img src="http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01117.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p>Now I just need to figure out the front. Who sells a long spline kit for the front axle I can install myself? Trail Gear has been out of their kits since the beginning of the month, and I would like something more than Marlins 8" kit.</p><p></p><p>~T.J.</p></blockquote><p></p>
[QUOTE="84Toyota4x4, post: 1093857, member: 16626"] Well, just as an update and a conclusion to this thread, I went ahead and did it myself. I cut the end off my old shaft in a vice using a sawzall following the weld edge and it came right out with some big channel locks. Did the same for the CV end, but it fought a little more, haha. Got them all out, made sure the cut end was square, then persuaded the CV into the tube with a 5 LB sledge. Once it was in, I made sure I had it in far enough but not too far, and made sure it was square to the tube. All looked good so I welded it up and shot it with some new paint. Got it installed (after swapping t-case flanges because there wasnt enough room to drill the new pattern), greased the joints and took it for a test drive. Went well up to 35 MPH with no vibes so far. No exhaust on it so I was trying not to piss off the neighbors too much. I still need to cut and rotate the rear axle as well, but it seems to work great so far. I ended up with 1.25" of spline compression travel, the rest is all extension. Of course some pictures as well... [IMG]http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01113.jpg[/IMG] [IMG]http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01112.jpg[/IMG] [IMG]http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01114.jpg[/IMG] [IMG]http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01115.jpg[/IMG] [IMG]http://i54.photobucket.com/albums/g89/tjay31584/New%20Suspension/DSC01117.jpg[/IMG] Now I just need to figure out the front. Who sells a long spline kit for the front axle I can install myself? Trail Gear has been out of their kits since the beginning of the month, and I would like something more than Marlins 8" kit. ~T.J. [/QUOTE]
Verification
Post reply
Yesterday at 9:18 PM
Yesterday at 7:44 PM
Yesterday at 2:04 PM
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
