Sold/Expired Built 87 Cherokee 2 Door
ridgerunner6477
Posting for a friend - Ok guys I found something I'm interested in so my Xj is up for sale. Please note this is strictly built for offroad, in no way is it street legal....
87 two door, auto, sye kit, 7.5 RE lift with acos adjustable spacers, Dana 44, chromoly shafts , spooled 4.88's, ruff stuff diff cover, Dana 60, 4.88's, spooled, Great Lakes offroad diamond plate diff cover, disc brake conversion. Humvee bead locks, 36" tsl sx's grooved, Binks fab bumpers , new smittybilt 10000lb winch, rci 10 fuel cell mounted inside, rear shock mounts built inside cab, I have a cube light mounted on the hood and smaller flat 4 bulb one mounted under the from bumper, original gas tank was removed and exhaust is run up high n tight where tank used to be. Interior is gutted besides front n rear seats. New aluminum radiator, Brand new PSC extreme hydro assist kit..."not installed yet"
I wheel the hell out of this rig and it never let's me down, it's not pretty but it gets the job done. It does need some stuff done before it's perfect but I wheel it now the way it is. The upper n lower control arm bushings need to be replaced. A new track bar should be made and mounted up a bit higher "old one broke and one was just ghetto fabbed to get me by" I blew a rear shock so there's only one out back now. Windshield is cracked, body had plenty of dents. I have an extra set of doors. Rear main seal was just replaced. Rear bumper needs to be welded back on. A 96 tranny and transfer case was put in. I have a spare 36" tsl sx on a humvee beadlock but I punched the sidewall, I have a patch plug in it but it still leaks, another patch on the inside should do the trick. I removed the tail lights, the wiring is still there. Hydro assist key needs to be installed. I'm probably forgettin something so if ya have any questions feel free to ask. $6500 located in warrior run pa 18706 message for faster response
