Sold/Expired Built 87 YJ for sale
wngrog
>POSTING FOR TERRY<
$10,500 Located in Jackson MS
Black 87 YJ SBC350
Contact Terry Williams ( 601)-624-3578
This is Pat Holland's Old YJ so you know it is done right!
* conversion radiator and Novak mounts
* SM 465 trans with new clutch and pressure plate trans was totally rebuilt with new main shaft to accept the 231 crawl box or Dana 300 transfer case, has the back cut 3rd gear also (Novak Kit).
* BOX4ROX 231 crawl box only uses the planetary
* Stock D300 transfer case flipped to drives drop with Duffy's easy flip levers,
* Does Not leak a drop
* 1988 Ford Kingpin Dana 60 Front with Full Detroit Locker Stock shafts 35 inners and 30 spline outers
* 14b Rear 4.56 gears, welded spiders with stock shafts and disc brake setup using 3/4 ton chevy stuff
* 42X14X17 Iroks on Hummer H2 wheels with Staun internal beadlocks and 2" spacers
* Hydro assist steering using EMS parts, stock pump and box. 8" single cyl and HI Steer arms DOM tie rods& drag link
with 3/4 heims
* .Custom White Rhino skid plate with trans and tcase mounts.
* Traction bar mount here also rocker guards and custom cage built by Duncan Motor sports tied to frame
* Summit racing seats tied to cage with 5pt harnesses (current dated)
* Stretched to 105" wheelbase with rear Dodge Dakota springs and front Alcan offset springs SOA with a White Rhino traction bar .
* 15 gal RCI Fuel cell mounted in the back.
* Stock fuel gage works
* All stock gages work except clock, Tilt wheel, CD stereo CB, Have the stock fenders if you want them.
* Warn XD9000i
* On Board Air York compressor with tank and rear outlet
* Spare Drive shafts front & rear and spare Front axles shafts & lockouts
