rmarnett2002
Active Member
- Joined
- May 27, 2014
- Messages
- 35
Alright her it goes guys. I'm putting the TJ out there for sale.
Engine:2.5l has maybe 8k miles since rebuild
62mm throttle body swap-1 trip since installed
K&N filter
Electric Fan Conversion
Stock 5 speed trans
Drivetrain: Stock Dana 30 front
Extended front driveshaft-1 Trip since installed
NP231 with rubicon express SYE with olivers driveshaft
8.8 rear swap with disc brakes
4.88 gears front and rear
Novak cable shifter conversion
New front hub bearings-1 trip since done
Front SOLID high capacity diff cover-1 trip since done
Rear SOLID high capacity diff cover-1 trip since done
Spartan Locker in front
Aussie locker in rear
Body: Smittybuilt frontbumper with stinger
10" led lightbar mounted on winch
Quadratec 9k winch
KC headlight conversion
Custom hoodline front fenders
Smittybuilt rocker guards
Smittybuilt rear full corner armour
Rear led taillights
New TNT customs rear crossmember bumper-Not installed
2" led spotlights on winshield-1 trip since done
Fresh camo tan paint-1 trip since done
Rock light just installed
Kilby gas tank skidplate
Rampage bowless soft top
Suspension: Front upgraded 1 ton steering-1 trip since done
Front rubicon express adjustable trackbar-1 trip since done
Front steering box skid plate-1 trip since done
3.5" rubicon express springs with 1.25: spacer
Rough country long arm add on-1 trip since done
extended brake lines on front-1 trip since done
6" rancho 7000 front and rear shocks-1 trip since done
Rear BDS adjustable trackbar
1.25" Body lift
Interior: Rhino lined tub-1 trip since done
Custom roll cage done by Fall Out Fab-1 trip since done
Corbeau Baja ss seats with 4 point harnesses-1 trip since done
4 point harnesses in rear for passengers-not yet installed
Cobra 19 CB
Tires: 5 Matching firestone destination MT 35" tires that have maybe 5k on
them since purchased less than a year ago
5 matching procomp streetlocks
1.5" wheel spacers all around
That's about all I can think of right now. Don't have a lot of recent pics since as you can see most of it has been done recently and the rest was done last year. I have owned it for three years. Second owner and have done all the work to it as it was bone stock the day I got it. It is built to crawl but still turn heads around town. I have done all the work except the cage myself and have done all maintence to it as well. I am and ASE tech by trade and know how to take care of and fix my cars so rest assure its a solid jeep. Has not even been pushed to what it is capable of doing. Hard for me to get rid of it but im looking to do something different.
The bads: Discovered this weekend that the novak cable wasn't adjust right so it only engaged in 4HI N and 4LO so it need adjustment. has a valve cover gasket and I figured out yesterday that the front axle seals are leaking.
Asking 12K obo or trade for something bigger with maybe 1 tons,40s,350 etc.
If you add up all I have done its well over 14K in add on retail plus the jeep.
K&N filter
Stock 5 speed trans
Quadratec 9k winch
Rear led taillights
1.25" Body lift
Cobra 19 CB
