SOLD! !!!!!
UPDATED with pictures of the axles cleaned up and a fresh coat of paint on them.
Front full width chevy low pinion D60, 4.65's, Detroit, RVC shafts, rockcrusher drive flanges, Toyota flanged yoke (this can be swapped out to a 1350 if needed) Solid outer knuckles and keyed 6 bolt high steer arms. Spare pass side stock chevy knuckle with high steer arm (The axle has the stock knuckle mounted on the passenger side and I have the Solid knuckle/high steer arm that has never been mounted, honestly to lazy to mess with it so you can swap the Solid stuff to the passenger side and sell the stock knuckle or whatever) Axle is setup for a 4 link and coilovers, single ended ram, tie rod. 4000.00 firm
Rear full width Low pinion D60, 4.56's, Full spool, 35 spline Chromoly shafts, disc brakes, setup for 4 link, coilovers, swaybar. 1000.00 firm
Pictures will be up soon. Axle's need to be pressure washed.
Located in Mount Olive, Alabama. Will ship but you will need to set up everything and have it paid for up front. Will accept check or cash. If you send a check it will need to clear before I ship the axles.
I will do 4700 for the pair if picked up and you have cash in your hand. Prices are firm as I do not have to sell. Not interested in any trades.
