Sold/Expired Built Jeep TJ part out(or sell whole)
Hardline Crawlers | Rock Bouncer Builds, Tech & Off-Road Trail Talk
fl-krawler
1
I have made the choice to part out my TJ in order to finish out my buggy and go back to wheeling it..
1997 Jeep TJ Frame/tub/tube fenders. Frame has no original bracketry on it. It is set up currently for 4 link susp. and a LS1/nv4500/d300 combo. The rear of the frame has a BTF back half kit. The frame has custom tubular rocker guards/nerf steps, and 6pts, for roll cage tie in. Jeep tub comes with 1 extra dash and all the components I have to put a/c in the jeep. Jeep has a clear FL ***le and VIN. $1500
6pt roll cage. Custom 6pt family style roll cage. Goes through the dash and requires no mods to the A/C duct work, only some dash trimming. Cage fits factory soft top, and has soft top frame mounts on it. Cage uses factory seatbelts, but has seat mounts built into the cage(seat mounts can be removed if you desire something different). $1500
700R4 transmission. GM 700R4 trans.. I bought this as a rebuildable core and should be treated as such. $200
Jeep D300 T-case. All stock $200
Advance adapters 700R4 to D300 adapter. This part is new in the box, and mates a 4wd 700r4 to a D300 http://www.advanceadapters.com/products/pn-50-6309/ $400
Chevy D60F/14B rear. Both axles have 27,000 original miles on them, and were fully rebuilt this past supper and have less than 1000 miles on them. Axles have new brakes, wheel, and diff bearings. Rear axle has been converted to disc's. Front axle has a spool,as well as BTF hi-steer arms, and rear is still open. Both axles have new 5.38 R&P in them. The axles are also currently trussed and set up for 4 link susp. and hydro steering $2500
19.5/44-15 Boggers on Weld wheels. Almost brand new with less than 1000 miles on them yet. Mounted on weld racing 15x16 alum. wheels with an 8x6.5 lug pattern. 1 wheel is bent slightly. No cuts or other damage. $2000
(2) LS1 engines. One has Painless harness, delphi "mini" ecm, aftermarket cam, and beehive valve springs. Engine reciever new rings, bearings, and reseal during the jeeps buildup. Also comes with new alternator, and TC power steering pump. $2500 The other LS1 is bone stock other than a LS6 manifold. No acc. included with engine. This engine has 20k miles on it. I have not run this engine but compression is good, and only visable proble with it is part of the starter boss has broken off, which is a common problem with LS1's.. $1500
Fuel cell/cell cradle. This is designed to be used with the BTF back half kit, and keeps the fuel cell under the jeep instead of behind the back seat when stretching the wheelbase. Fuel cell holds 13 gallons, and comes with a 0-90ohm sender. $200
Full doors with roll up windows.. Doors are in perfect shape other than one small crack in the door panel. Doors are yellow in color, with grey panels. $500
Half doors. Doors are in good shape with black paint and grey panels $350
TJ door surrounds $50
(8)4 link control arms. 1.75" x .250 wall DOM arms with 3/4 x 7/8 heims and misalignment spacers. Arms are between 36" and 45" in length. $500
Pictures of the parts can be seen here in my FB album
http://www.facebook.com/album.php?aid=7838&id=100000499020994
Prices are open to respectable offers, but I am not open to any trades other than for the following parts:
Baer 6psc calipers
Spidertrax 8 lug rotor hats
Tubeworks 14" extreme brake rotors
Mastercraft pro 4 seats
All parts are located in Zephyrhills Fl, 33541 and I will ship on the buyers dime. Almost all the parts are used and should be considered bought "as is". I will also not hold parts for anyone without a non refundable deposit, and first one to get me a deposit or payment for the parts gets them. I dont get topic reply notices here so it is best to email me about the parts at [email protected]
is it all together. or have you disassembled it? does it run and move under its own power? is there a package deal... for everything?
Yes its currently still together, and runs /drives. I DD the jeep 2-3 days a week.. I would have to get $18,000 for it to sell it complete. Here is some video of it from last sunday
Jeep campout Jan 2011
Mud hole
pics of the half doors
I will also sell just the windshield frame, and also the tubular rocker guards by themselves
bump
Both sets of doors are sold
D300 is sold
AA adapter is sold
do you still have the 700r4 transmission, if so is there any issues with it or what? please contact me at 256-739-1771 ask for Cody
No, unfortunately I got rid of it and the rest of the jeep about 3 years ago
