Sold/Expired Built rock crawler, only 10 rides, central Indiana $22k
PurdueCAT
Active Member
Well I have come to the realization that all the good offraod parks are just too far away for my work schedule so Im putting my buggy up for sale. Specs to follow:
$22k
Chassis is a mix of DOM and HREW
112" wheelbase
19.5" belly height
43 tsl sx sticky
Allied Rock a thons
2.5 FOA remote res coilovers 16" front 18" rear, (no problems w these whatsoever)
Viper coil springs
Dana 70 rear 6.17 gears yukon axles,
custom dana 70 front dedenbear inner knuckles alloy usa 1.5 35spline axles,
Yukon rear axle shafts
Spidertrax drive flanges
CTM joints,
psc double ended ram, and orbital,
corbeau seats,
four link front rear with 1.5 chromoly hiems, 2" 7075 links,
warn XD9000 winch with rope
Atlas II 3.8
RJM Wiring harness
351w w/5.0 mustank fuel injection
30lb injectors
Jet hot shorty headers
A9P comp.
Alum heads
Professional products throttle body
ARP head studs
Nascar MLS head gaskets
FlowKooler water pump
Fuel system
Howe Steering cooler
KRC Steering pump
Aluminum steering wheel
Braided Earls Brake lines
Aluminum fuel cell
Sprint car washable fuel filter
Northern aluminum radiator
Phenolic intake spacer
Wilwood throttle pedal
Wilwood brake pedal w/dual master cylinders
Hurst quarter stick
Manual reverse valve body
Deep aluminum trans pan
Locking dip stick
Gilmer crank/water pump/alternator pullies and belt
Optima yellow top
2 speed Electric fan
2 maxx out fire extinguishers
Chassis is built for a shorter driver but the pedals could be reworked for someone taller, or a different set of seats. ( I'm 5'7") Only thing it could use is a good quality starter. The current one struggles when it absorbs heat off the header (update:starter issue resolved) It is ready to ride now! Id consider a partial trade with cash for a fatboy (harley) or a nice streetable early bronco.
(Brand new yellow top and starter fixed issue above).
Brad
765-432-9949
Work 3rd shift, prefer texts
Can email pictures, or text them
Re: Built rock crawler, only 10 rides, central Indiana $34k obo
Bump for a great rig, rode with brad & this rig gets it done!
The stickys make all the difference!
U need to come on down to gray rock Aug 3rd and we'll test them out!
I just need to move down there!
bump $28k need space in my garage
I have wheeled this several more times, but I'd still let it go.
Re: Built rock crawler, only 10 rides, central Indiana $28k
This makes me a little sad Brad!
Bump for a killer rig though!
Yea, I love it, it's just a pain to travel all over to use it. Can't get away that much...
