crawler nut
- Joined
- Dec 25, 2010
- Messages
- 701
93 YJ with ***le
117inch wheel base
Full cage 1-3/4 .120 wall DOM
Suspention
4 linked front an rear
Ruff stuff 4 link towers for Rockwells
Ruff stuff Cryo heat treated heims 1-1/4 bottoms 7/8 uppers.
Link bars 2inch .250 wall DOM
16inch Fox 2.5 Air shocks front an rear the ones with the black ends
Axles
2.5 ton Rocks de-braked with Pinion breaks slotted rotors an Wilwood calipers
Wheels
H1s- re-centered with rock pattern with cut down mag run flats. With Mudpro rock rings
Tires
Almost brand new Swamper 43sx
Engine
LQ9 6.0 out of an 05 Escalade 78k. Jims Perf Hot tune, Jims harness. I changed it over to DBC with a new throttle body. Lokar throttle assembly. New plugs an wires.
Aluminum radiator with Taurus Fan Engine has Never been over 205deg.
New MAST oil pan.
Ceramic coated shorty headers.
Trans
Cooks Racing TH-350, 16-1800 stall,TCI reverse manual valve body, Derale 2 extra quart pan, with Derale fan cooler, with all stainless braided hose with AN fittings
Winters shifter.
Trans case
203/205 doubler the 205 is Chevy round bolt pattern twin sticked, built by Traveler on here. I think is now HeMan motor sports.
All drive shafts built by Carolina Drive line. 2 piece front drive shaft carrier also built by Traveler
Custom dash with all Autometer 2-5/8inch guages. Oil pressure,Trans temp, water temp, volt, Fuel, an 5inch tach
Winches-Front Warn 8000 with synthetic rope. Rear Warn 2500 with synthetic rope.
ViAir on board air. 2.5gal tank, ViAir 450 continous duty compressor.
12 VOLT GUY large switch panel.
Hella HID head lights.
Black Corbeau Baja SS seats
4 point harnesses.
Steering
Brand new 1 ride PSC 10inch double ended ram. with Deral fan cooler for steering. PSC reservoir all stainless braded with AN fittings front to back. except from orbital to ram.
RCI 15gal fuel cell
Walbro 255 fuel pump, Summit inline filter, corvette regulator, all stainless braided 6an line front to back.
I know I have forgot things, so any questions ask away.
Engine has been in for 3 rides When I first built the rig I had a 355 on propane in it, so all the fuel stuff i mentioned is new.
price is 20K or would trade for the right buggy. Not looking for a hill killer. Just a nice clean buggy.
Will get up pictures tomorrow. I can text a few but will get some good ones up tomorrow.
Call with any questions 828-779-4221 Located in Hendersonville NC
117inch wheel base
Suspention
Axles
Wheels
Tires
Engine
New MAST oil pan.
Trans
Winters shifter.
Trans case
4 point harnesses.
Steering
RCI 15gal fuel cell
