Sold/Expired caliper bracket
broncorckcrwlr
66 bronco
I need a drivers' side caliper bracket for a 78/79 Ford Dana 60 front end. A Dana 44 bracket off the same years will work if it is an eight lug. OR, a pair of brackets off of a 85-91.5 Ford Dana 60 will work if I use the different caliper which is fine with me because I need calipers too. ::)
I am pretty sure I have some. I will not be home till Thursday. Call me after 3:30 256-431-8618 . They are for a Ford Dana 44
I have a complete chevy dana 44 8-lug you can have for cheap. Uses the common and cheap single piston GM caliper, just change the outers to use the GM stuff. Post or PM, Rich
