truck-oholic
- Joined
- Dec 22, 2013
- Messages
- 460
Need cash ASAP so taking a loss.
Chevy king pin Dana 60 with 4.88 gears and Trac-Lok limited slip. Has Artec high steer and front truss with hydro mount. Artec parts were $650 alone. Original spring perches and shock mounts are still in place. Has a RockCrusher diff cover, Warn lockouts, and stock shafts. Roughly 68.75" WMS.
All the Artec stuff was a fresh install, never ran, and I believe the gear set was done at the same time. If full hydro isn't your thing you could still use the ram mount for a single ended hydro assist ram and run a conventional tie rod with heims below the arms and the draglink on top of the passenger arm.
Located in Spring Hill, TN 37174. Local pick up only. Cannot ship at this point.
$1,500 cash bottom dollar, come and get it.
Thanks,
Jesse
610 999 1546
Thanks,
Jesse
610 999 1546
