Sold/Expired Chevy LS / LQ and small block 350 engine mount brackets!
motobilt
"I Build Stuff"
1
Dothan, AL
http://www.motobilt.com/brackets-tabs/ls-lq-engine-mount-brackets.html
Mounting a LS / LQ based engine in a tube chassis, Jeep, hotrod, ratrod or other application is made easier with these mounting plates. The plates are a builder part. You will be required to fabricate mounts to the plates. The brackets are CNC cut from 1/4" high strength steel plate. The brackets sell in pairs.
http://www.motobilt.com/brackets-tabs/small-block-chevy-mount-brackets.html
Mounting a Small Block Chevy 350 in a tube chassis, Jeep, hotrod, ratrod or other application is made easier with these mounting plates. The plates are a builder part. You will be required to fabricate mounts to the plates. The brackets are CNC cut from 1/4" high strength steel plate. The brackets sell in pairs.
