KILLERB468
need a K case if you have one, if not 2wd will work.
KILLERB468 said:need a K case if you have one, if not 2wd will work.
badreligion_13 said:There is no such thing as a "K" case TH400...Many rumors claim otherwise. I have confirmed this with a couple of different builders to...In the TH400 the cases are the same with the exception of a thicker flange at the bellhousing for the 4Wd version.. 700R4 and Th350 have K case...In the TH400 you may find a "HD" case.
KILLERB468 said:I have always refered to the K case as a 4wd case, Yes a "HD"case is what I need,
