CJ7 8.1L Eufuala Al
406Jeep
New Member
1986 CJ7
8.1L (496 cuin) L18 LS big block, Raylar BP202 truck cam, .510 / .545 lift; 224 / 237 duration; 116, Trick Flow roller rockers, 1.7:1 ratio
Griffin radiator, 3" core with Derale 16" electric fan
Transmission, 4L80e, (1) ride since rebuild
Advance Adapters Atlas II Transfer Case, 3.8 : 1
Front and Rear Axles both with ARB RD99 air lockers, True Hi9 diffs w/ 5:38 gears, RCV axles
PCS power steering pump, remote reservoir, orbital valve and hyd ram
Rear Coil Overs, Fox 2.0 Emulsion Shock, 16", remote reservoir, Ebaich springs
Front Air Shocks, FOX 2.0 Factory Series Air Shock, 16", FOX 2.0 Air Bumps, 4"
Tires and Rims
- (4) Interco Boggers, 18/39.5x16.5
- (4) Mickey Thompson, Classic Rims, aluminum, 12x16.5
1 1/4" 4-link rod ends and tube adapters
2" x 1/4" wall DOM links
Rear is 4-linked, never got around to doing the front. Worked well enough with the front still on leaf springs that I never took the time to finish it out. I will include the tube, tube ends and rod end for the front 4-link if the buyer wants them
$32,000
