Have way too many parts. Planning to be at Hale Mt. this weekend. In Harvest, AL, willing to ship.
Make offer
*** 22r parts ***
-22r intake with carb, air filter housing, distributor, coil
-complete weber 32/36 conversion for Toy
-carb 4runner tank
*** 22re parts ***
-resistor for 87 ish injectors
-2x low oil pressure switch (not sender)
-22re ign coil (19070-35130, 053 Ex)
-22re distributor
-22re cam (has pitting from rust)
-22re cam (slight rust)
-efi 4runner tank
-ECU 35630
-ECU 35070
-ECU 35610
-ECU 35010
-early style knock sensor (with pigtail)
-pickup fuel pump bracket
-early 22re lower intake with injectors and rail
-fuel pump to hardline high pressure hose
-late 22re intake (upper and lower) with rail, nicely painted red (good for 5 extra hp)
-22re 2wd oil pickup / pan
-coolant return hardline (goes around alt)
-late air intake tube (has extra tube molded alongside for air injection system)
-engine to tranny bracing/webbing for auto (holes not threaded)
-engine to tranny bracing/webbing for manual (holes threaded)
-old style AFM (boxy)
-22re head with cam and rockers
-22re head with rockers no cam
(one of these had a chewed up #4 cylinder from what looks to be a dropped valve)
-late injectors (red top)
-early injectors (grey top)
*** misc parts ***
Ford EDIS 4 cyl system
Make offer
*** 22r parts ***
-carb 4runner tank
*** 22re parts ***
-22re distributor
-efi 4runner tank
-ECU 35630
-ECU 35070
-ECU 35610
-ECU 35010
*** misc parts ***
