Coilover Bumpstops
little crawler
Beltucky
What bumpstops are you running with coil overs? I thought i read that you can use stock TJ bumpstops that will slide over the shaft of my coilover?
I've seen a similar setup on a few bilstein coilovers, not sure if it's standard, or an option, those thing's come far from ever compressing so hopefully losing a few inches of up travel is cool with you. It's not like a typical bumpstop that is mounted inboard that allow's the axle to pivot around, anything with a 7/8" ID will work, I don't know what the id of the tj bumps are.
