Custom Axles
MonnlightRacing77
When in Doubt Throttle Out
Sullivan,MO
Custom steering axles 14 bolts,80s, D60s,D70s bare housings prices.Custom 40 spline rear non steer axles as well!
Retubed 14 bolts just tubes $800 setup for all dana 60 front shafts kingpin to 05+ or rear steer.
Super Duty 14 bolts with Cs,knuckles $1200 up to 74in WMS seals included!!
Kingpin 14 bolt with solid Cs $1600 with seals add new knuckles for $495
Brand new 4in 14 bolt housing $400 upcharge on listed prices
Dana 80 with 05+ Cs and Knuckles $1600 with seals
Unit Bearing rear 14 bolts $1450 with Mark williams cups
Kingpin 14 bolts $7400 complete
40 spline SD 14 bolt steer axle $8250 complete ready to GO!
Jeep crate axles available also 44s to 1-tons
Don't see the axle setup you are after or have question feel free to send a PM
TTR Axle and Fabrication
Specs on "40 spline 14 bolt steer axle $8250 ready to GO"
Is that any/custom width or a a standard width? What shaft/joint/drive slug setup? Gears & spool?
Up to 74in wms custom or standard offsets 3.5x.5 wall DOM tube.
Branik 1550 40 spline shafts,billet joints and slugs with lifetime Warrenty
Revolution gear
Mark Williams spool
Forged yoke of choice, 1480 is $40 extra
Or upgrade to mark williams billet for extra $200
American Iron upper and lower deletes
Timken Unit bearings with bolt pattern and stud of choice
13 bolt shave and cover, 15 bolt shave extra $400
Mark Williams brakes
JHF high steer arms, bolt on aluminum arms $400 extra
Fabricated 9/10in axles now available in 3.5 and 4in tube.
Bare housing 3.5in is $850 with .375w tube
Bare housing 4in is $1000 with .375w tube.
Any C and knuckle combo available for these. Can also build complete in LP or HP setups.
New product available from TTR Axle and Fabrication
Lightweight 05+ Super Duty 60 brakes kits.
Kit include (2) Wilwood Dynalite calipers and pads, (2) 1.25in vented rotors available in both 8x170 and 8x6.5 bolt pattern, with calipers mounts and hardware. Great way to lighten up that heavy 05+ SD60! Lose 65lbs with ease.
$575 for the whole kit
05+ 35 and 40 spline 4340 1550 Axle shaft kits.
35 spline inner and outer kit with Branik Legacy joints and slugs $1875
35 spline inner and 40 spline outer kit with branik legacy joints and slugs $1925
40 spline inner and outer kit with Branik legacy joints and slugs $1975
Custom inner $100 extra each shafts
35 or 40 spline stubs $250
35 or 40 spline slugs $250
Branik Legacy 1550 Joints $700 a pair
CTM 1550 Joints $900 a pair
Diff Covers in stock ready to ship!
¼in Faceplate with ½in thick flange.
Dana 60/70,Dana 80, Sterling 10.25/10.5 and GM 14 bolt covers!
13 bolt Covers as well.
Lifetime Warrenty
$175 Shipped
