gray tj
MOTOR: 2006 LQ9 6.0L Dyno Tuned 450hp.
Sanderson headers
Moroso Racing aluminum oil pan
TRANSMISSION: REID racing Billet Turbo 400.
reverse manual valve body
all upgraded internals
PTC 2400 stall.
Art Carr shifter
TRANSFER CASE: ATLAS II 4:3:1 1350yokes
FRONT AXLE:1979 FORD DANA HP 60.
CRANE KNUCKLES AND HI STEER
DETROIT LOCKER 4:88's
CTM U JOINTS
chromoly 35 spline inner/outer shafts
drive slugs , 1/2 ton brakes and rotors
REAR AXLE: 2001 shaved 14 BOLT GM
Spool w/4;88's.
STEERING: PSC double ended ram/with aluminum links
PSC steering cooler
SUSPENSION:Front and REAR 4 LINK w/2" Aluminum links and 1 "3/4"Heims
ORI STX STRUTS 16'rear.14"front
WHEELS AND TIRES 85% 43"TSL SX STICKIES..on 17"RACELINE Aluminum beadlocks.
FUEL SYSTEM: Custom Aluminum Fuel cell by Wide Open Designs
All fuel lines are AN fittings/line/fuel pressure gauge and regulator
COOLING SYSTEM:Griffin Aluminum dual pass radiator
Dual SPAL fans.
All cooling lines are AN fittings
INTERIOR:All custom dash and floor.have to see in person.
WINCH:WARN 8000LB.All chassis tubing is D.O.M. 1"3/4"
Miscellanous:On This buggy has every part has less than 8 rides on them.
I am listing this for a friend,the buggy is located in central florida.Please contact Shaun at 352-302-1866.more more pics/and questions asking 26K....
Sanderson headers
PTC 2400 stall.
Art Carr shifter
CTM U JOINTS
Spool w/4;88's.
PSC steering cooler
Dual SPAL fans.
