Sold/Expired Custom RZR/atv trailer....Nice
Marty
NC
I took an 08 Moomba ski boat trailer and made a rzr trailer out of it. I pulled it one time since I built it. I never haul my rzr or anything else with it so it just sits there. Its about a 4k dollar trailer new. I spent alot on it. The paint even cost over 100 bucks a gallon because its a special dupont industrial paint for boat trailers. I cut out all the old curved crossmembers and the back section and welded in new rectangular tube braces. I also straightened the rounded tongue so you get a square deck. The deck is 14' and I believe the trailer is about 7' wide, but I need to double check. I also stained the wood floor with an outdoor stain. It has surge brakes. LED backup lights and LED signal and stop lights. Trailer has no ramps because I dont like the clanking things so I designed it to use aluminum ATV ramps, but I set it up so you could fit some ramps in the back and make them slide in.The reverse wire on your vehicle's 7 way plug must be working to pull this trailer or it will lock the wheels when you try to backup. Comes with a brand new UWS toolbox. Trailer sits high so it will not drag anywhere. Has brand new 245 Maxxis bighorn tires on 16" black procomp aluminum wheels. Asking $2500 located in NC, Clear NC ***le. Not sure how much trailer weighs but its not real heavy.
