Dana 300 pattern-need quick
Jeepasaurusrex
Marysville, WA
Dana 300 pattern-need quick (Home grown clocking)
I know the Dana 300 bolt pattern is 6 bolts, but on what radius? Does anyone know right off hand? Need this quick! Thanks! :beer:
What I ended up doing, was using the CNC program on our burn table to create a disc with 12 holes in it, on a 6.75" radius. I skipped 3 holes on one side. I bolted the disc up to the adapter on the transmission.
232323232%7Ffp%3A95%3Enu%3D3563%3E35%3A%3E257%3EWSNRCG%3D337253624%3A335nu0mrj
I used the blank area where I skipped the holes, and marked the odd hole location there (marked in white). I drilled that hole location in the disc. I then rotated the disc counter-clockwise to the next hole. I bolted it in place then I used a transfer punch to mark all the hole locations.
232323232%7Ffp%3A84%3Enu%3D3563%3E35%3A%3E257%3EWSNRCG%3D3372535%3A88335nu0mrj
232323232%7Ffp%3A82%3Enu%3D3563%3E35%3A%3E257%3EWSNRCG%3D337253629%3A335nu0mrj
232323232%7Ffp%3A92%3Enu%3D3563%3E35%3A%3E257%3EWSNRCG%3D3372535%3A74335nu0mrj
I kept the disc bolted up and drilled all the new mounting holes. I am going to have to trim a little off the shifter ears of the T-case and possibly one corner of the transmission case. Overall, it's going smooth.
:redneck:
