Sold/Expired Dana 60 thick Milled High Steer arms with Knuckle tie in kit
4WHEELSUPPLY
1
Just finished this new arm today. It is a newer version of my standard arms with tie in kit. They are a combination of my thick milled arms and my tie in arms. so now you can have the best of both worlds. 3/4 Hardware for knuckle tie in kit is included. As well as a set of studs for the arms.
$200 to your door.
What you will get:
1 pair of arms (1 pass 1 driver)
2 Pcs of 3/4-16 Grade B7 all thread
2 pcs of 3/4" ID DOM
4 Nylock Nuts
1 set of (8) studs and nuts
1 Springless conversion ( set screw, jam nut, and custom thick washer)
YOU CAN ORDER DIRECT FROM MY WEBSITE HERE! Four Wheel Supply - Dana 60 thick Milled High Steer arms with Knuckle tie in kit
These arms are also avail in a double ended arm.
Glad to see you made it to HL.
The best value in steering arms right here. You can start your new years workout with these! Pure beef!
Re: Dana 60 thick Milled High Steer arms with Knuckle tie in kit
Ordered mine Tuesday, got them today, drilled up, cleaned up, painted, now I can finish putting my junk together and try to be ready to ride Friday. Thanks for a beefy set of arms and great customer service.
Finally got these installed on the jeep, went together very well
