Sold/Expired Delete
Re: WTB Good 22r Head and 31 or 33 Mud Tires
Think you posted this in the wrong forum! Doubt you can get good head here. :****:
I have an Engnbldr performance head and cam id sell
Re: Re: Re: WTB Good 22r Head and 31 or 33 Mud Tires
kmcminn said:
My block is an 83 model. What all different year model 22r heads will work?
84 and earlier "open chamber" heads
Edit for incorrect info, whoops.
Is it single roller 83 :dunno: I got one of those bastards sitting in my storage.
TBItoy said:
All 22r and re heads will work on your engine
Toyota redesigned the 22r&re engines in '85. The block, head, timing chain, and timing covers do not work on the pre '85 motors.
If you have an '83 block, you will need a pre '85 head. The '85 -'95 heads (and blocks) have a 2mm shorter deck height and a "closed" combustion chamber for flat top pistons. The early models have "dome" top pistons with a ring that sticks up above the block and "open" combustion chambers. If you put an '85 up head on the early block with the dome pistons, it won't even turn over because the piston will hit the head.
Re: Re: WTB 31 or 33 Mud Tires for 15 wheel
Could you run 35's?
Ive got some 35 a/t's. Mix matched. Some rot, but overall decent. Also have 3 procomp xterrain 35's... dunno if you'd be interested in any of those.
