Sold/Expired Delete
SPOA87YJ
coo-whip
$old
Re: Jeep 4.0l PSC pump
Im interested. Is that a 1650psi pump? And if you don't mind me asking what kind of clearance issue did u out have?
Not sure on the psi specs for this as I got it 2nd hand. I built my shock hooks around an xj style bracket. This pump style interferes with my shock layout so I'm just going to run what I have from my old motor.
PM replied to Jrowe
Will this pump not bolt up to the Xj bracket? Other than the built in resivoir it's the same as a stock jeep pump.
i haven't tried. I plan to pull the brackets off the old motor and inspect further. i think the bolt pattern is different....
This is a stock tj pump. It looks just like a PSC pump only has a tank built on it. It will bolt up just like any tc style pump. So the psc "should" bolt right up to your bracket.
This is a PSC pump I just bought. Figured it might help. I've wasted a lot of money buying stuff I thought I needed and didn't lol
