Rock Crawling Forums
Difference between metal and wood chop saws?
Reply to thread
Message
<blockquote data-quote="KP81" data-source="post: 1528477" data-attributes="member: 16020"><p>with an abrasive blade go for it. I have an old all metal Makita I use for steel with an abrasive blade its fine. I don't know I would use a plastic saw because of the heat its going to put off.</p><p></p><p> If you are talking a carbide blade for steel you can not use a wood chop saw it turns way to fast and you are either going to get hurt, ruin your saw/blade or hurt someone else it shouldn't even be an option.</p><p></p><p>I use a regular wood saw at work everyday for cutting aluminum, but that is a whole different story there due the lower tensile strength if aluminum and we use a blade that has a high number of teeth with a blade designed for aluminum.</p></blockquote><p></p>
[QUOTE="KP81, post: 1528477, member: 16020"] with an abrasive blade go for it. I have an old all metal Makita I use for steel with an abrasive blade its fine. I don't know I would use a plastic saw because of the heat its going to put off. If you are talking a carbide blade for steel you can not use a wood chop saw it turns way to fast and you are either going to get hurt, ruin your saw/blade or hurt someone else it shouldn't even be an option. I use a regular wood saw at work everyday for cutting aluminum, but that is a whole different story there due the lower tensile strength if aluminum and we use a blade that has a high number of teeth with a blade designed for aluminum. [/QUOTE]
Verification
Post reply
Friday at 3:12 PM
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
P
YouTube of the day
Latest: paradisepwoffrd
Monday at 8:21 AM
Cash LeCroy Illness
