64FJ40
Purely theoretical since my potential project list is already approaching triple digits, but...
Anybody attempted this?
I was just perusing through some catalogs for drainage pipe (yay! Exciting
) and started looking at the IDs of various solid-wall HDPE high-pressure water main pipe. It would be pretty easy to come up with a suitable insert and ~3/4" HDPE seems like the ideal material for this purpose.
If you used a steel wheel with a continuously-welded center section (do those exist?), you could just slice the front half of the shell off at the joint, weld a circular mating flange with a machined groove for the o-ring onto the half you cut off, drill some matching holes in the existing center, and be set right?
Other than the machining of the mating flange, it seems like it would be a relatively cheap way to build double beadlocks. Feel free to point out the flaw here (or if it's already been done).
