Sold/Expired Easiest way to 4 link a Jeep YJ...
Hardline Crawlers | Rock Bouncer Builds, Tech & Off-Road Trail Talk
motobilt
"I Build Stuff"
1
Dothan, AL
The Motobilt Jeep YJ 4 link / Skid system is the easiest and fastest way to 4 link the front and rear of your Jeep YJ. This kit is located by the factory skid plate holes and welds into place. The the upper and lower mounts are fully boxed front and rear. This kit was designed to take abuse. Once the factory mounts are removed you can have the kit bolted in place in a few minutes ready to start measuring for your links. This kit should not be confused with a production built suspension lift part. This kit is built much heavier for large tire applications with many different engine tranny combos in mind. If you have questions feel free to call me or email.
The kit includes the left and right link assemblies, the bottom skid plate, and the two weld on skid attachment points.
The skid hangs down the same amount as the factory skid plate. In the pics is looks deeper because of the overall size and the vertical sides of the bottom section. The upper link mounts go up to the inside of the frame rails.
CLICK HERE TO SEE THE KIT:
http://www.motobilt.com/suspension/3-4-link/jeep-yj-4-link-suspension-mount-kit-skid.html
Nice. What is the frame end separation? I see it has 3 adj. holes.
