Factory d60 calipers with solid knuckles problems
earls69
I have a set of factory chevy d60 calipers and running solid knuckles having clearence issues once bolted up don't have room for brake line and banjo bolt brake caliper is hitting the knuckle has anyone else had this problem thanks
Yeah and its just as dumb as when you will have to grind your Yukon shafts down to clear the hole in the knuckle. I grinded some on the brake line and stuff but you are going to have to grind on the knuckle.
