fl-krawler
- Joined
- Aug 27, 2009
- Messages
- 525
I am thinking about selling my TJ project. I am considering it b/c of 2 reasons, 1) b/c I have lost all intrest in it, and I have another project that could really use the funds to be finished up, and 2) Even though I love my current truck, I have come to relise that I hate automatic transmissions, so the other portion of money would go towards buying my wife something with an auto, so I can trade my current truck for one with a manual(since this will be the last year they are selling Superduties with a manual trans).
My asking price for the project is $15,000 Firm and I am not looking for any trades. If you feel I am asking to much for an uncompleted project, I dont really care. I have close to $25,000 invested in newly installed or yet to be installed(still in the box) parts on the jeep, and will not consider selling it for any less than my asking price.
Build thread for the jeep can be seen here:
http://www.floridajeepers.net/viewtopic.php?t=50962
Specs are as follows:
1997 Jeep Wrangler SE (originally had a 4cyl/5spd)
Interior:
Full A/C system from a 1999 Jeep TJ. Entire A/C system including the compressor are jeep parts
Full 6pt roll cage( has mounts on it for the factory soft top)
Factory dash, modified slightly for the cage
(2) new garage pro's seats( mastercraft rubicon knockoffs) not installed yet
factory rear fold and tumble seat not installed yet
Full auto meter ultra light gauges(tach, speedo, water, volt,fuel,oil pres.) not installed yet
Drivetrain:
LS1 out of a 2000 model camaro. Engine has a comp cam,, beehive springs, ***anium retainers, GMPP roller rockers, painless wiring harness, mild head shave(11:1 comp). The engine recieved new main bearings, rings, and a complete reseal when the cam was installed.
I have all the fittings, hose and alum. hard line to plumb the entire fuel system in -AN fittings
New Walbro fuel pump
New Wix corvette fuel filter/fuel pressure regulator
Custon hand built 1.75" primary headers, exiting into madrel 3" exhaust, flow master mufflers and chrome tips
New reman'd GM NV4500. Advance Adapters bellhousing(w/ external slave), along with a Centerforce clutch/flywheel. Trans. also has an AA NV4500 to D300 adapter on it
D300 transfer case. Stock but I have the parts to twin stick it
New Griffen Alum. radiator, w/ taurus fan. Radiator has been modified to use -20 AN style fittings and hose fittings and hose not installed yet
Axles:
Chevy D60 front. Axle has 27,000 original miles on it. I also have new in box 5.38 gears, spool, master install kit, wheel bearings and brake parts.
Chevy 14 bolt rear. This axle came from the same truck as the front. Disc brake conversion, using new front 3/4 ton rotors, 1/2 truck calipers and weld on brackets from BTF. I also have new still in the box 5.38 gears and a master install kit for this axle.
I have all the nesassary fittings and T's to plumb the entire brake system in -3 AN
Suspension:
Fox 2.0 x 16 remote reservior coilovers at all 4 corners
Custom 4 link susp. using 1.75" x .250" wall DOM and new 3/4 x 7/8 QA1 heims.
Currie anti-rocks front/rear front not installed yet
Wheelbase is 110"
A custom cradle was built in the back of the jeep to hold a custom 16 gallon cell under the jeep. I have the sheet of alum. and all the sending units, filler neck, and fittings to build the cell.
Tires/Wheels:
Brand new 19.5/44-15 boggers w/ 100% tread
15 x 16 Alum. Weld racing wheels
Steering:
Danfoss "load reactive" orbital, mounted to a custom bracket on the firewall.
Custom steering shaft to mate the factory jeep column to the orbital
Performance offroad 2.5" x 8" stroke double ended ram not installed
Derale aux. cooler w/ fan not installed
BTF hi-steer arms
The jeep is about 85% done. I have all the parts to finish the jeep minus the rear driveshaft and a few minor other things. I also have a new in the box painless CJ7 "chassis" wirings that I planned to use. The list of things to finish are as follows:
build fuel cell
plumb fuel system
plumb brake lines
plumb coolant hoses/ heater hoses
plumb steering hoses
build passenger side tubular rocker guard
rear driveshaft
add seatbelt mounts to the cage
build front seat mounts( or mount them to the factory mounts)
mount steering ram
mount front swaybar
build a bezel for the gauges to fit in place of the factory cluster
install/mount wiring harnesses
mount steering cooler
build/buy front tube fenders
grille mount
install gears
Everything on the jeep has not been fully welded, and will need to be, as well as everything get painted still.
I will assist the buyer in any way I can with getting the jeep finished, or I can be convinced to finish out the jeep before the sale for additional monies. Please keep in mind I have no urgency to sell and I am dead firm on my price. I am also NOT! interested in parting the jeep out, or any trades( unless its a partial trade for a 08 or newer diesel crew cab Ford with a manual tranny, or a 04 or newer chevy tahoe(loaded) so please dont bother asking, as I will not reply
The jeep is located in Zephyhills, Fl
Interior:
Drivetrain:
Axles:
Suspension:
Wheelbase is 110"
Tires/Wheels:
Steering:
BTF hi-steer arms
build fuel cell
plumb fuel system
plumb brake lines
rear driveshaft
mount steering ram
mount front swaybar
grille mount
install gears
