Firewall Material
Lil ugly
Jacksonville, Fl
I am in the middle of my buggy build and am constructing the firewall. I have intended to make it out of steel mainly because I will have a child with me most of the time when I wheel and felt that it would give some additional protection from fire or other issues. However I would like some other opinion on Steel vs Aluminum, as I would prefer to save the weight if could. Thoughts or comments?
I ended up using .125 aluminum for my firewall and floorboards. I'm glad I did no regrets. It's a little costly though.
Lil ugly said:
Thank you for the responses.
Did you use 2021 grade aluminum or something stiffer?
A lot of what is commonly available to me is 3003 grade. .125" is my favorite to work with.
When doing complex pieces anneal the panel to 675-700 degrees to make it easier to work as most of the commonly available grades will work harden quickly when worked cold.
