Sold/Expired FJ80 axle parts
Mavros
Active Member
I need an open carrier and spider gears for a fj80 axle.
Also need a set of 5.29 gears
FYI
you can use a v6 carrier in a hi pinion diff (they use the same carrier bearings)
I have a hi pinion open carrier that I replaced with a v6/lock right diff.
I'd sell it for basically nothing...
contact info and location?
Thanks for the info, i didnt know that.
How much you wanna sell it for and ship it to FL?
Also do you know if I can put some manual hubs on a fj80?
I'd ship it to FL for $50. I'm never gonna use it...
there is info on IH8Mud/Pirate about manual hubs. I believe on the older non-ABS (short stub) FJ80s that mini truck hubs will bolt on. I think a spacer or something is needed for ABS trucks (longer stub shaft)
You can also cut a new groove for the locking hub snap ring on the longer Birfs.
