Sold/Expired For Sale: Trucks, transmissions, beadlocks, 42/15/15 pitbull rockers w/beadlocks
Roy_Hobbs
Tupelo, MS
Here are a few things that im just not using anymore, feel free to ask questions, im sure i will leave some needed info out, can post, pm, or text 6622130618. In tupelo, ms.
4- 42/15/15 Pitbull Rockers on 10.5" Steel beadlocks, 3" bs, 8x6.5 lug, 90% tread, no rash, no plugs, no patches, no cuts. $1800
4- old school white spokes painted black with weld on beadlocks 15x9.5 (8.75" from inner lip to outside of inner bolt ring plus your tire bead thickness), nothing fancy but they are tough. 3.75" bs - $250
2- Sm420 trans (one had worn synchro in 2nd, popped out from time to time, other one condition unknown but spins freely) $150 ea
1- Sm465 mated to np208 , i think its a 208 not sure ( never used but spins freely). $300
1 - Ford 435 4 speed, should be good, i know where it came from and spins freely. $200
2 - Large bore (4 5/8") gm cast iron bellhousing, they fit sm465, not sure what else they might fit. $50ea
Late 70's J10 Jeep Truck, does not run, have not tried to fix, but spun motor with shot of ether and engine fired, didnt take it any further. 360 engine, auto (quadtrack) offset rear d44 and front d44, track width close to 64". 3.73:1 i think. $500
1993 Chevy Z71 Cheyenne, manual windows and rubber floor 340000ish miles. Needs keyswitch (was using around the house when contacts just finally gave out) and solenoid plunger for 4x4 frontend. 350 tbi only has about 20k on it, .30over flat teardrops 8:1, mild pulling cam (voodoo?), old style heads (2.02 valves)worked with 3 angle valve job, intake rebored to fit. good engine. 4L60E Tranny also has about 15000 miles after rebuild, would be a good hunting or around the house truck. $1400
Black spokes
trannys
bellhousings, J10, Z71
