1badcomanche
Active Member
Selling my ford buggy. I hate to do it but the time has come to let it go. It has a 302 motor bored 30 over with alum. edelbrock performer rpm heads , cam, 1.6 roller rockers, edelbrock intake and is run with holley fuel injection. Alternator is a mechman 240amp. Autometer 2 5/8" gauges oil, temp, and volts. Transmission is a c6 followed by a atlas 3:0.1 transfer case. Front driveshaft is a 2 piece all 1350 driveline. Rear driveshaft is a ag spline shaft with 1410 at transfer case and 1350 at rear end. Front axle is a kingpin ford high pinon dana 60 with full 35 spline chromoly axles and drive flanges. Rear axle is a full floating dana 60 that has had the spindles bored and chromoly 35 spline axles installed. Axles have 4:56 gears. Front has 2" x 14" fox coilover shocks and fox 2.0 bumpstops. Rear has 2" x 14" fox air shocks. Tires are 42" tsl's with aliied beadlock wheels that have custom beadlock rings. Fuel cell is alum. 10 gallon and will last for a day of trail riding. Belly pan is cut from 1/2" 6061 alum. Belly pan height is 19 1/2", buggy is 70" tall, inside width is 50" and wheelbase is 119. Has wilwood dual piston pedal assembly. Has corbeau seats. Im 6'2" and buggy is real comfortable. I have been wheelng buggy for 2 years now and have hardly had any problems with it, and i have put it to the test many times. Buggy handles and feels great on hills.
Price is 17,500 or i will let go for 15k and i keep motor minus accesories and im located in Maryville tn which is near knoxville. Call or text for faster responce 865-556-8834
NO TRADES Thank you
Youtube link with walk around of the buggy
https://youtu.be/1QFuv8D_3Ys
NO TRADES Thank you
