Sold/Expired Ford NP 205 front output shaft
blzrgb
Earth
Swapping out the 30 spline GM for a 32 spline Ford. If you got one or have the whole Ford case, call 662-279-1236
What all do u have to do to swap them out.. Just curious.... I have a ford 205 with a missing rear output
you remove the front output shaft from the ford and put it in the chevy, and chang the front output seal to the same as the tailshaft seal. . It is that simple....unless... you happen to have a chevy 205 with sychronized shifter...then it is not so simple.
Well guess I need to figure out which one I got then... Think for the info.. Might try that if front breaks
