[email protected]
New Member
- Joined
- Apr 17, 2014
- Messages
- 3
- Reaction score
- 0
a pair of 8 lug axles dana 60 rear, 44 front (driver side drop) with disc brakes, 4.10 gears, out of 77 f250 highboy $600.00 for the pair,$200.00 for all the highboy factory leaf springs. dana 44 front , driver side drop from f150 , five lug ford, 4.10 gear, track lock/posi, hardly any miles (les than 500 since all was new $400.00, 9" rear housing and 31 spline axles, no chunk $250.00, np435 granny four speed, less than 1,000 miles since rebuilt, married to a np205 t case for drivers side drop, 351M,400,429,460 bellhousing, centerforce clutch $500.00 for all, 429CJ engine, I put PI heads on it for better low end torque (the dooE heads were sold a long time ago) engine was rebuilt, had only less then 10k miles on it and wiped a cam lobe, I installed a new performace cam, timing chain. I decide to replace all bearings and oil pump again, since I was there and that's where I stopped, needs to be put back together with new bearings and oil pump, since I threw all that away. it was balanced when rebuilt, has forged flat tops and the good rods, and a fairy new stealth intake $1300.00 for the engine. I have a np435 four speed for a divorced t case, $200.00, 9" rear end housing and axles out of early bronco, its narrow, about right for a jeep, ranger , explorer or s10, $150.00 I have a complete early bronco chassis, 9" rear end, dana 30 front both have 4.10's, has a six cylinder, three speed and dana 20 t case $700.00 for the whole rolling chassis and drivetrain. the np435 four speed will replace the three speed with a 100.00 adapter. complete and running 77 f100 4x4, 351M, granny four speed, 44 front, 9" rear, body a little rough, good fixer upper $1200.00 selling all this so I can focus on my early bronco trail rig and my 78 f150 cummins turbo transplant. located in griffin, GA 40 miles south of Atlanta call or text 404-732-6550 I can help arrange shipping.
