Front deck toyhauler, build
leeman1790
Alabama
Hoping to get some opinions/ideas from hardline. I picked up a camper from a guy I work with for 800bucks, it ended up being in way better condition then I expected. Pretty much everything works except the AC, which isn't cooling, and a missing window pane on the left side. and He put a new roof on it 2 years ago. My 2 days of thinking plan is to clean the inside up some and update it here and there. Probably add some Led lighting. and that it's short enough to cut the tongue off it and build a deck to drive a RZR on sideways.
My rzr sideways would be too wide according to the law. How strict are they on that? also thought about building the main tongue/frame and having a thin deck on that mounted to a truck hub bearing where I could load sideways then spin it around in line with truck and trailer. But I'm already thinking it would be long for a bumper humper.
I plan on having to brace the frame back to the axles to keep it from shearing in half or frame flex ripping my new stabbin cabin apart. Need to look into the 5lug axles it has too. Whatch y'all think?
Here's the camper and some new setups similar to what I was thinking
Re: Front deck toyhauler, possible build
I bought the midsize ranger cause of how short it is in overall length. I've found they are very lienant on the width law, unless you are pulling a commercial trailer.
Who cares if its legal, you live in the south. front or back, same amount of fab.
Yeah im around 112" right now nose to tail
:wtflol:
Not sure I'd want 12-1300 lbs. hanging off the back with the axles in their current location, plus up front the truck can take some of the weight.
probably going to have waaay tooooo much tongue weight after you reinforce the frame, build a deck and load a RZR up front. if you notice on those commercially available units they have the axles no more that 50% back from the front of the RV portion.
Far as the law is concerned about width, it should not be a problem unless you get some jerk who wants to mess with you. In my area of SE Houston, I am way more concerned about the number of trailers with bent axles drifting down the road then I am about someone being a little over width.
Watch out for those 5 lug axles, some camper manufactures actually use less than a 3500lb axle (as low as 2600lb I think???).
Buy the smallest utility trailer that will fit ur sxs and pull doubles. Looks like the camper might have a receiver on back.
Sent from my iPhone using Tapatalk Pro
What's the length and weight of the camper as is?
Personally I like the idea of using the hub to side load, then spinning everything around to straight, but that's mostly because I think it sounds like a cool idea.
The actual camper part is around 20'. Then add another 3 for the tongue.
I thought the side load spin setup would be cool too. Its not off the table yet
I measured the truck with the trailer hooked and unhooked. The truck drops 3/4" with it on. So I don't feel like ill have too much tongue weight. I have airbags on the truck too. I got the tape measure out and pulled my rzr around to get a idea of what I'm looking at.
The wood block is 64" off the front of the camper which is what I'd need for a spot to park.
and then just a couple pics to get a idea of what I'm workin with.
I'm probably going to be breaking the plasma cutter sooner or later. Double trailers would be easy, but not exactly what I'm looking for.
I see what you are talking about with the axle placement. Looks like the RV sections arent quite as big on the factory ones too. Hopefully I can get away with just a little on the heavy side or cut it all back off :****:
I did a little searching on tongue weight and issues people had, I found some stuff but they were going to be using a tahoe, half ton pickups and such.
A little too much tongue weight is way better than too little. As long as ur fab work is on point and check ur hitch for corrosion or weakness's or maybe go with a higher class receiver, slap some load leveling/anti sway bars on it and be good.
I'll be updating with pics of the addition in the next week or so
I've been doing sliders and front/rear bumpers on a 4runner so hopefully I'll have that out of the way before I go back to work next week and knock my camper out in a day or 2. But the guy I got the camper from told me about one he saw that was similar to what I had talked about doing to his.
I drove out there today and...Sure enough it's almost exactly what I had in mind. It looked pretty original to me, nothing cut or patched together and the frame is wayyy taller than mine. Mine is boxed and this was c channel. Who knows, but you get the idea of what I'm about to do
Swapped all the lights out to LED. Also changed some of the exterior markers to 2 bulb setup
