Sold/Expired FS/FT 1997 jeep tj streetable trail rig *NEED GONE* new price!!
Jacksonwolf39
New market, al
Here I have a 1997 wrangler that I'm looking to let go as much as I hate to. I've i got a lot of money and time wrapped up in this jeep. This is a great jeep and does great offroad. Wouldn't recommend as a dd but could be with a couple changes. Drives straight down the road tho. Drive it to the trail wheel all day and come home. Here's some specs
155,xxx miles 4.0 auto 231 transfer case SYE kit
Dana 30 front full Detroit locker chromo shafts heavy duty steering set up jks adj trackbar 4.56 gears g2 diff cover heavy duty upper and lower control arm mounts
Dana 44 rear brand new full Yukon grizzly locker brand new us alloy chromo shafts new brake assembly 4.56 gears g2 diff cover heavy duty upper and lower control arm mounts new bearings and seals through the whole thing
Antirock sway bar setup up front
Rear cv driveshaft
6 inch rough country long arm kit
Poison spyder front fenders
Rock sliders
Rear corner guards
10k Smittybilt winch
Custom front bumper
Smitty rear bumper have the tire carrier for it
New CD player all new speakers
15 inch steal wheel
36 tsl SXs that have rock rash and chunks missing. Only good for offroad.
Custom roll cage added on to the factory
12 inch led light at mounted on winch fairlead
*will come with a new top*
bad- winshield cracked, longer I have it most likely I will replace it, leaks oil after its been running awhile not much tho and doesn't burn oil or use it besides the leak
price 9000 obo
interested on doing some trading on Toyota truggy built samurai anything offroad really. vehicle wise. just looking to getting into something more capable.
located new market al call or text 256 694 4674
Re: FS/FT 1997 jeep tj streetable trail rig
Interested in a 1 ton cherokee on 38s. It has clearance for 42s. Message me if interested.
Bump for new heim joint steering set up! Jus gotta make a new sway bar bracket
New sway bar mount on and sway bar hooked up. Drivin down the road pretty dang good.
Re: FS/FT 1997 jeep tj streetable trail rig *price drop*
It's a solid well built jeep. And I can guarantee you it's been babied! :flipoff1:
Interested txt me 8143897090
A/c work?? Where's it leaking oil from,rear main??
Didn't come with AC. And either rear main or pan. Havnt really checked it out. Like I said I've had to add oil maybe twice since I changed the oil 5 months ago. No more then a pint at a time
