Indy Will
Fuel Cell is RCI1322G - 32 Gallon
Cell was taken apart and I painted the metal can on the inside (not painted when you buy them) so it's not a rusty mess inside.
Shimmed the cell in the can with plastic to prevent it from slamming around.
Has dual internal Walbro GSS340 pumps wired up for one to be a primary and the other to be a spare on a custom plate with fuel pump tower.
Pumps have newer prefilter socks on them. Changed them at the end of last year.
No baffles or foam.
Tube float 0-90ohm fuel level sender.
-8 output
-6 input (has a reducer from a -8 if you wanted it though)
-10 vent line port
Dimensions 26" x 18" x 18"
I was just in the cell at the end of last year and everything looked fine. It's been sitting on the shelf since then after I sold my buggy as a roller.
I can't find the screw on cap though, might have to order a new one. I had it plumbed with an extension filler cap on my buggy so never used it. The original threaded bung is still there (under the duct tape in the pic) so it'll screw right back on.
It's been through some use and does look a little rough but it's in perfect working order. Needs a little cleaning up, but no rust.
That's not rust, just a little caked on mud. Needs a pressure washing...
$400
Cash or Paypal if you cover the paypal fee.
I can ship it but it's probably going to be upwards of 50 bucks. It's big.
In Burlington, NC.
Will at 336.693.4003
No baffles or foam.
-8 output
-10 vent line port
$400
In Burlington, NC.
