Sold/Expired Fully Built Rock Assault Axles from CCOR!
CCOR
706-559-9609
Athens, GA
Fully Built Rock Assault™ Front Axle
You asked for it and we delivered! Trail-Gear is now offering Fully Built Rock Assault™ Front Axles! Made entirely of brand new parts, these axles feature everything you need hub-to hub, including a precision installed tie rod and drag link! The only additional items you will need to make this kit work are a pair of tires and a vehicle to bolt it on to.
This is a fully assembled front axle made entirely of brand new, upgraded components, not refurbished junkyard parts. The Trail-Gear Fully Built Rock Assault™ Front Axle features your choice of Toyota Rock Assault™ Axle Housing width, and comes with upgraded 30-Spline Birfields, 30-Spline Chromoly Axle Shafts, our Fully Loaded Six-Shooter Knuckle Kit, Chromoly Spindles, upgraded Brake Rotors and Calipers and a heavy-duty tie rod and drag link, all expertly assembled by our Master Mechanics! Each Fully Built Rock Assault™ Front Axle will include Trail-Gear’s upgraded Trail Safe™ Seals and Super Metal Knuckle Studs in addition to all other necessary nuts, bolts and seals. Axle options listed below. Save the time, money and hassle of ordering each component separately and building it yourself. We’ve already taken care of it!
Customize each axle to exactly what you need with your choice of:
Axle Width
Axle Offset
Differential
Hubs or Flanges
Trunnion Bearing upgrade
***Please note these fully built axles are for Leaf Spring applications only. No other bracketry should be welded onto assembled axles. If you are interested in purchasing this kit for 3-link or 4-link applications, we can send all components for your assembly. Please contact our Sales staff with any questions.
Fully Built Rock Assault™ Rear Axle
In response to overwhelming demand, Trail-Gear is now offering fully built rear axles! These feature our world renowned Rock Assault™ Axle Housings, our complete Rear Disc Brake Kit, Chromoly Axle Shafts, Bearing Pockets, Rear Axle Bearing Service Kit and all the necessary nuts and studs, all fully assembled by our Master Mechanics according to your specifications!
Rock Assault™ Rear Axle Housings provide unparalleled strength due to the 5/16” thick, high strength DOM axle tubes that engage 5/8” further into the center section and the 360° gusset welded around the tubes on the inside of the housing. The Trail-Gear Rock Assault™ Axle Housings also feature axle tubes that have been offset above the housing centerline to allow the inner axles ride near the bottom of the axle tubes rather than in the center. The results are an increase of 3/8" ground clearance under the axle tubing. The heavy-duty, press formed, 1/4" plate steel center section shell is specially shaped to ensure a minimum of 3/4" additional clearance under the differential. The differential mounting surface is made from ½” plate steel to ensure studs cannot pull out, even under heavy loads. The outer offset flanges are made from 4130 Chromoly to prevent distortion or bending. Housings are precision aligned using start-of-the-art, 3D digital imaging equipment.
Made entirely of brand new parts, these axles feature everything you need hub-to hub! This is a fully assembled rear axle made entirely of brand new, upgraded components, not refurbished junkyard parts. You choose the Axle Width and desired differential and we do all the assembly. All you’ll need to do is weld on your perches, install it on your vehicle, add the wheels and Rock the Trail! Save the time, money and hassle of ordering each component separately and building it yourself. We’ve already taken care of it!
Axle Width
Differential
Fully Built Rock Assault™ Samurai Rear Axle
Axle Width
Differential
CALL us Today at 706-207-4140!
