Terryjmatthew
This is the front axle from my old trail rig. High pinion diff w/ 4.10 gears. Old style ARB locker. One of the bolt holes from the air collar is wallowed out a little bit, but everything works just like it should. Housing has had a few birfs blow up in it and it is pretty rough looking. The inner axle seal on the right side doesn't seal well as is, but could be cleaned up with some sand paper and it would seal much better. Comes with an ARB mini compressor and all the wiring to make it work. Backlash is set pretty tight because it was set up for a trail-only rig.
Land tank caster plates and radius arms (although one is bent) are included.
$1250 obo in Auburn, AL
