85toyo
Have a few things laying around the shop that I need to get out of the way. Prefer to sale locally.
exhaust manifolds off of a 2001 6.0L LQ4. 20$
power steering and alternator bracket off the 6.0L 5$
stock Dana 60 diff cover. 10$
Fuel cell that I believe is a 15-16 gallon. The fuel pick up on the outside of the tank has a few inches broken off. Also, it needs to be cleaned out. It measures 25"wide,17" front to back, and 9" tall. The two fittings in the sump are included with new washers but I forgot to get them from the shop so they are not pictured. 40$
Northern brand aluminum radiator. The inlet has been cut and welded at a angle for a tight fit. Missing the radiator cap. It's beat up but should work fine. Measures 22" overall width, 17" core width, 18" core height, 2 1/4" core thickness, 1 3/4 OD outlet, 1 1/2 OD inlet. 40$
The fuel cell and radiator were bought used and I decided to upgrade before using them.
Parts are located in Trussville AL 35173
Call or text 2053059973 thanks Jacob
