Sold/Expired !!!!!!!!!!!!!!!!!!!!!!!!!!!!!Garage Sale!!!!!!!!!!!!!!!!!!!!
bigbird
89 Suburban 3/4 ton 4x4 TBI 350 Turbo 400 NP 208. This would make a cheap hunting rig. Drive anywhere. Clean and clear ***le. $1300 !!!!SOLD!!!!!!!!
GM Turbo 400 and NP 203. Complete with torque converter. $400 !!!!!!SALE PENDING!!!!!!!!!!!!!
GM Turbo 350 and NP 203. Complete with torque converter. $175
GM SM 465 granny low 4 speed and NP 203. Includes bellhousing, tranny and transfercase adapter, flywheel, and cluth. The NP 203 has been dissasembled but is still all there. $400
GM SM 465 and NP 205 Complete. $400
GM 4x4 Turbo 350 $50
GM 4x4 Turbo 400 $200
GM 2 wheel drive SM 465 granny low 4 speed $100
GM Turbo 400 to NP 203 adapter $150
GM Turbo 350 to NP 203 adapter $50
GM NP 208 with 32 spline input. Includes shifter and should bolt up to late model SM 465 and or Turbo 400. $100
Genuine Gear Dana 60 Reverse cut High Pinion 5.13 gears. Brand new $150
GM dana 60 front single wheel hubs with rotors $250
GM dana 60 front Dual wheel hubs with rotors $175
Factory GM dana 60 spring plates $50 a set. I have three sets
FF 14 bolt 5/8" U-bolts brand new $40
Dana 60 Blue Torch Fabworks Heim Joint High Steer arms. $250
Bare GM dana 60 front housing with inner C's $200
Dana 60 4.10 and down ARB air locker. Brand New $750
Scout II dana 44 front and rear axles. The front is complete and the rear needs new gears $150 for the set
4" factory ford lift blocks $20
Poison Spyder Jeep CJ full width kit $300
63" GM leaf springs. 3 sets. $75 a set
Jeep CJ 4" lift.
4" springs
6 Rancho RS 9000 shocks
1 incab adjustable system for shocks
dropped pitman arm
4HD shackles
2 Front Braided stainless steel brake lines
HD u-bolt skid plates
JKC sway bar disconnects
81-86 Factory front shock mounts
$250 for everything
20,000lb snatch block $40
10,000lb chrome tow hooks with mounting hardware $15 a pair
CIPA Custom Tow Mirrors for 98-02 Dodge pick-up $25
Just like these http://cgi.ebay.com/ebaymotors/DODGE-CIPA-TOWING-MIRROR-10500-PAIR-1994-2004_W0QQitemZ150301602592QQihZ005QQcategoryZ33649QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Edelbrock 1405 Carb Like new $150
Sunpro Drag-n-tack with shift lite 0-10,000 RPM $30
Moroso 74131 Switch panel with wiring $50 http://store.summitracing.com/partdetail.asp?autofilter=1&part=MOR%2D74131&N=700+4294849326+400105+115&autoview=sku
4 19.5/46-16LT Micket Thompson Baja Claws. Around 75% tread $800
39.5x13.50-17LT super swamper Iroc's I would guess around %25 tread. $150 for all 4
4 2006 Chrome plated OEM Hummer H2 wheels with center caps and lug nuts. 17x8.5" 8x6.5" bolt pattern. Brand New Take Offs. $400
GM Tilt column
73 auto $100
80 auto $100
79 auto $100
Jeep CJ factory Hard doors $300
Everything is located 15 miles north of Wamego KS.
Can provide pics upon request
PM'd
Edit: mm should look at original post date. Who dug up a 5 year old thread. O well no harm in asking if stuff is still available.
