Sold/Expired GenRight COMP cut Full Corners for TJ, YJ or CJ
JRowe
For Sale: Gen Right comp cut corners. BRAND NEW still in packaging. Paid $358.62 shipped to me.
Will Sell for $300
Located near Nashville, TN
PM or call me at 615-202-3093
From the GenRight sight.
This is the GenRight Off Road "Full" COMP Cut Corner Guard set for the Jeep TJ, YJ or CJ-7. These are a perfect upgrade to better protect your Jeep’s tub.
This model is an ideal choice when stretching your rear axle back more than 6” and running 37” or bigger tires.
FEATURES:
* Wheel opening is moved stretched 4” back to help fill in the empty space left in front of the rear wheel after stretching the wheelbase.
* Laser cut from 3/16" thick SOLID steel plate, just like our other Corners.
* The 90 degree bend is formed with a single "hit" die on a CNC press brake to assure this product matches the shape of your Jeeps tub.
* This Corner Guard is specifically shaped to keep the rear body mounts intact for better over all structure.
* There are NO CUT OUTS in these corners, just the mounting holes. Mounting the tail lights & gas filler in this version is all up to you.
* The mounting holes are pre-drilled and countersunk (we use 2 more mounting bolts than other brands) to secure the corner to the tub.
* Includes large 5/16" size countersunk Stainless Steel bolts (flush type) to securely mount our corners to protect your Jeeps tub and look clean!
* Fits on top of most 6” tall after market 3/16” thick Rocker Guards (rock sliders).
* Includes (2) 3/16” thick rear tailgate hinge spacers (if you are still have them), since the hinges would bolt on top of the corner guard.
