snevey
Wheelin the countertop
There is only one right way to build a 6 lug 14 bolt with disc brakes. The wrong way would be to start with a stock 6 lug SF axle. Our kit converts the common 8 lug Full Floating axle to 6 lug and comes with forged and CNC machined hubs.
Our brackets are machined from 3/8" hot rolled steel plate. Sharp edges are deburred before sand blasting and powdercoating satin black. The kit includes a set of brackets, Grade 8 mounting hardware and a pair of forged and CNC machined 6 lug hubs to fit the 14 bolt FF.
This kit narrows your axle by 2.25"
This kit will work with 15" wheels
CLICK THE LINK https://www.sneveysoffroad.com/gm_14_bolt_ff_6_lug_conversion_kit/4_wheel_parts_off_road_parts
Note: Axle shaft flange must be turned to fit the wheel over the shaft flange.
These are meant to replace factory hubs that are 6 inches long. In some cases the rotor must be opened up to fit over hub.
What else will you need?
• (2) Raybestos Rotors Part # 5020 (1983 GM 1/2 ton 4x4 truck front) Open the bore to 4.3"
• (2) Calipers (1975 -1988 GM 1/2 ton 4x4 truck front)
• (1) Set of brake pads (1975 -1988 GM 1/2 ton 4x4 truck front)
• (2) Soft brake lines (braided stainless steel lines available)
• (2) Banjo bolts
• (12) Dorman Lugs Part # 610-381
If you want to keep your cable e-brake simply substitute '78 El Dorado rear calipers instead of the GM front calipers. Our brackets will work with both calipers.
• (2) Banjo bolts
